"Firefox Focus is using battery" notification
  • 1 பதிலளி
  • 3 இந்த பிரச்னைகள் உள்ளது
  • 6 views
  • Last reply by Foxkeh_12
Every time after I use Firefox Focus, I get a notification:
"Firefox Focus is using battery Tap for details on battery and data usage"
Tapping that takes me to a page showing info about the Firefox Focus app. The notification persists unless I Force Stop the app.
Pixel 2 XL, Android 8.0.0
Every time after I use Firefox Focus, I get a notification: "Firefox Focus is using battery Tap for details on battery and data usage" Tapping that takes me to a page showing info about the Firefox Focus app. The notification persists unless I Force Stop the app. Pixel 2 XL, Android 8.0.0
From the text given, it sounds like a bug in the system in either firefox focus, or in your android software. The two systems may not function well together in the current version, try to update firefox ficus if you can or wait till an update probably, or do a software update.
